My new 9210 often locks up when synching with my PC. I tried re-formatting it and installing software downloaded from Nokia (It's OS 4.13) as well as installing the 9210i PC link software on my PC. It still happens sometimes, requiring a reboot.
Any ideas?
i guess its not your phone. this happened to my comp & phone as well. soon i backed up my comp stuff & then reformated my C drive(on my comp). now it works perfectly fine.
hope this works.
or try this.
uninstall the pc suite & then install it on your D: drive (ie. if u have a partition)
i guesss this would work.
i dont know y this happens, but it works.
let me know what works.
HyPeR
oopps... forgot to login
this is me gauravonline (HyPeR)
pc suite sometimes not working well when syncing and backing-up your 9210 data.
i suggest to use an MMC card reader. it's way much simpler and faster!!
I reinstalled the PC software after nuking all traces from my computer and the windows registry. It did the trick and works fine now 😃
Thanks!
