I have a 6 in 1 memory card reader, can i some how put the install files on my memory card THEN install it once my phone is started up?
Please say yes!!!!
E-mail me at [email][email protected][/email]
or aim at the s/n: deathtofate
Thanks a lot.
Please say yes!!!!
Thanks a lot.
Put the .sis files in the root/top directory of the MMC.
On the phone, go to [Application] Manager and select the application to install from the list.
anybody knows the dutch name for aplication manager??
I think it's toepassingen
but when I put a .sis file on my main dir of the mmc
"toepassingen" doesn't see them
What I did was create a subdirectory and installed all the *.sis and *.jar files on them (via 6-1 card reader).
If I want to install them, I use a file manager...fexplorer or file manager (I just click the center joystick and it installs automatically)
I can also send (via blue tooth) some files to colleagues.
what do you mean bij install in a directory?
i just copy and paste them from a map on my pc.
also apps like "torch" aren't foud anywhere
or do I first need to install File manager?
Do you still have the boxes you phone came in mate?
