using the 6600 as a webcam
10 replies · 5,313 views · Started 05 January 2004
I have searced and could not find any info on this.
Can the 6600 be used as a web cam for use with MSN messenger on my home computer?
thanks!
yeah via bluetooth, use a tool called Remote 60. It can capture streaming images from your phone and send them to your pc and have them uploaded to a ftp of your chouse.. and it will be updated at the time you specify.. I have mine set to every 5 seconds..
Thanks, I have treid Remote60 before and its cool, but I was looking to use the cam facilty in MSN messenger on my home computer. Cheers
p51,the 3650 was able to do what you are asking for.It might work for the 6600 too,search the 3650 forum.
thanks Ghostdog,
I found the thread and its up and running great.....but (theres always a but isnt there?) as per usual the camera keeps timing out and going to standby. Does any one know of a way round this?
I know theres no way to alter the time out time, but do any of the photography programs that are around keep the camera constantly active?
A program to keep "pinging" the camer to keep it active would be most useful.
thanks!
p51 can u post the link with the information on how to do it?
I also want to use it as a web cam with MSN
Ok so i have done exaclty how it says in the How To BUT when i use messenger i doesn;t work.
Instead of showing real time video it just shows a image (logo of Luminositi).
WHY THE F**K???? I have tried anything.
Anyone can help me?
p51 wrote:thanks Ghostdog,
thanks!
use flycam guys, google it. flycam does all the sh8t for u, no standbys n sh8ts n fckin irritating window lockin like softcam.
one for pc and one for fone exe goes to pc, sis goes to fone, install both and activate fone side flycam, open up msgr cam and it does all the sh8t for u.
