Image Enhancer
5 replies · 2,238 views · Started 05 January 2004
Hi
I have noticed some software available for 3650 and 7650 which will enhance the quality of the photo's taken.
Are there any of these apps available for the 6600?
Cheers
photographer work's fine on the 6600. It's on the trial and buy folder when you get your phone anyway so you can try it. The rip off is you have to buy the masks
@ �1.50 per set, not really a ripp - a fair price I'd say.
Plus you can always make your own and put them in the masks folder...
Best
Will
Plus the current downloadable masks once installed do not show up in the new version of photographer...
Give it a day or two and I'm sure they will have this fixed.
Will
