Hello there! Would you know if there is an available Call Counter and SMS Counter for the P900? The ones I had in my N3650 worked perfectly. I shall appreciate your thoughts on the matter. Thanks!
Call & SMS Counters for P900
I recall browsing in Handango and found a program called BillableBuddy, guess it might do the call counter trick, but for the SMS haven't seen any yet!
Thanks for your reply, Handyguy!
Your phone already has a built in call counters, if this would be any help to you:
That's right, muzikfreakah. However, the Call Counter I wanted contains details such as caller name with each caller's incoming and outgoing calls, number of calls for each day, total number of calls in a specified period, etc.
Anyway, thanks for the input.
