Nokia 6600 Carry-Cases?
6 replies · 1,686 views · Started 06 January 2004
Anybody know when they are coming out?
I have seen some that say they are 6600, but they don't look that good tbh.
I want a proper Nokia one, so I can still use all the functions of the phone without taing it out.
Cheers
I use the same box as for my 7650 from nokia (aluminium case) and it fits perfectly.
Domi.
look for the Krussel line of cases. They are quite good quality, much better than the genuine nokia ones.
I bought a product designed to protect the screens of PDA, it is basically a clear sticker that you use to protect the screen.
They cost about US $1 each in packs of 12, and you have to trim them to fit the screen, but they are basically invisibible and do a good job protecting the screen against pocket stuff like keys,
Andrew
Carphone Warehouse (UK) do a leather 6600 case with holes in the front for joystick and rear for camera.
Not a great case, but it does the job of protection.
�9.99.
Rob.
