Nokia 6600 Backlight
7 replies · 2,837 views · Started 06 January 2004
Is there any way to adjust the behaviour of the backlight - specifically when it asks for the lock code but doesn't light up until after you've entered it? - I find it a real pain not knowing if it is after menu|* or my 5 digit number
I just tap the power button. This turns the backlight on regardless of whether the phone is locked or not. 😊
Cheers
Is there a way to adjust the length of time that the backlight remains lite?
Ak04 wrote:Is there a way to adjust the length of time that the backlight remains lite?
This topic has being disscused before too.Then also use Torch as one of the freeware just on it and minimize it or use extended profile pro from psiloc and it will give u several option regarding this.
