ok
i bought my 6600 two days ago and i cant seem to accesss the drives menu.
Where u can see all da drives and the files inside(like MY COMPUTER)
DO I NEED a different file for that ... pls send it to me if i do.😞
ok
Use File Manager , FExplorer (free app) or SeleQ to browse your files ..
cya!
What files do you mean? You can access all the files from 'File Manager' in Tools (Except system files). If you want to access System folder, then you will need one of the apps AEFOX mentioned above.
Moving to the right forum...
