Sending Midis as MMS
18 replies · 6,398 views · Started 07 January 2004
Hi guys,
When I am trying to attached a sound clip(midi format) as an MMS message to my friend, the phone would show a error message which states as "Unable to insert. Object corrupted or format not support." Why does tis happen? Can anyone tell me pls. Thanks.
install a freeware application which gives u the abbility to send midi files over mms
its a greek freeware, allows to send FILES via mms!!!
name is :
mms_it.sis (6600 3650) AND
mms_it7650.sis (7650)
Same problem here.I install it for English but it keeps showing up in Greek.That's stupid or maybe it'a a bug.
Bye
if you download the source code, there are two language files in the inc folder, mms_it.l01 (english) and mms_it.05 (greek I think)
so I think a quick fix is to get rid of the non-english file and replace it with a copy of the english file, or whatever language you wanna substitute it with, it's quite easy to work out so you can translate it if you feel like it 😊
this way it has no way of displaying any language other to what you specify, then you obviously have to recompile the application and install it
cheers
Sam
How about, does anyone have an english version compiled? Please..
I know you can get by the bt transfer of DRM for .sis w/ fexplorer by renaming the file before sending it (this may be an option if you do email or even somehow mms..like changing it to a jpeg or whatever isn't DRM'ed but is still a MMS type). Then your friend just uses fexplorer and finds it and renames it/moves it. Haven't tested it, but it's worth a shot. If nobody comes up w/ a binary I might have to install the build env for this one. Someone come up w/ it please? 😉
i have a nokia 3650 and i tried "MMs it" but when i choose "send" i recieve an error message: "MMS: invalid access point"
(i can send any kind of MMS, only using MMSit i get this error...)
Is there anybody with 3650 which tried succesfully using MMS it???
thanks (and sorry for my terrible english :frown: )
The receiver has a 7250i (he can send and recieve midi files as he wants)... the error message i get is from phone... not from net...
I checked also the dimension of the midi (because of many operators have a limit of kb), but it was absolutely ok...
I searched in many forums and i only found people using MMSit on 6600 (and 3660 too) but i never found someone using MMSit on 3650...
I was thinking it isn't compatible... even though 3660 and 3650 are very similar...
what do you think?
Excuse me, i have a big problem..
For this program (mmsit) and others program there is one problem for me: Infact when i install it the same program-install stops itself and the cell returns how before.
Pls help me and excuse me for my english
bros, i couldn't access the website to download the mmsit application. Can anyone provide another alternative site.
Thanx in advance.
