Hi all,
I wonder if a virus on the 6600 or any other java phone is possible.
If thats possible, can they connect you to a payphone number?
That's a scary thought don't you think ??
So is it possible ??
NeXuS
Hi all,
NeXuS
It is possible on any programmable device where additional software applications can be installed.
The most likely way to get one, if one exists, is to install software from questionable sources (like pirated/cracked applications).
However, there are no confirmed reports of any viruses existing for your or any other phone to my knowledge.
