can anybody tell the detail setting for connecting hotmail account via gprs?
thanks
thanks
WAP to mobile.msn.com
Will
i was talking about connecting via the Email option present in messaging.
how do i set it up?
I cant really be done (well, if there's a will there's a way!)
Hotmail uses a web based http e-mail, and you are only able to setup a POP3 e-mail account, which will be the e-mail you have with your ISP.
However, you can install MSN messenger on your phone (ive got the file, but waiting for my IR device, so i can try it out) maybe you can get hotmail through this? E-mail me for the file if interested!
thanks a lot but can u please email me the file?
my email id is [email][email protected][/email]
thanks in advance
MSN has been sent to you in an e-mail! let me know how it goes 😊
havent recieve the email???
hope u typed the correct id
anyway here it goes again with 2 ids
kindly send again.
thanks
it doesnt work. i guess its not for 6600 cos it gave a warning....still i installed inspite of the warning.... but when i try to invoke it, it would do nothing......
anyway thanks a ton
try installing something called AppForge Booster, then try installing MSN! the MSN thing said something about P800, and when i tried installing a similar app (mentioning something about P800) it told me to install appforge booster... give it another go, and tell us how it goes!
