can someone please help me on the ff:
1. how do we get rid of the App. closed ectcpadapter_00808E5C, phone low on memory message after i sync?
2. why is it when i receive a message nothing shows on the screen to notify me and there's no message tone too! 😞
3. is there a 6600theme editor for mac?
4. how do i move messages from phone memory to mmc and vice versa?
5. why do we have to reformat our mmc?
6. i have 3 messages in the drafts and sent folder that i cannot erase!
please help me on this! you get a nice 6600 icon if you do (i know it aint much but its the least way i could repay you)
heeeelp!
Originally posted by mondo
[B]can someone please help me on the ff:
6. i have 3 messages in the drafts and sent folder that i cannot erase![/B]
1. Dunno (it works on my device).
2. Dunno (it works on my device).
3. No, unless you can run the Windows version in some Windows/PC emulator on a Mac.
4. See the Messaging Option "Memory in use" feature (also documented in the User's Guide, which is worth reading; doesn't take too long and will teach you a lot that otherwise will take time to figure/find out).
5. You don't, if it is already formatted correctly (16-bit FAT file system).
6. Too bad. Can't help you with that one (no such problem on my device).
3. i have the virtualpc but its very slow. do you have the cracked version of the editor?
4. >:P i aint dumb dude! what i meant was i have messages in my folder (w/c uses the mmc memory) that i want to move to my phone memory. what you're saying is choosing the memory that the phone's gonna use on coming messages before you set it to desired destination. i have the messages already and just want to move them to the phone memory so taht i could format my mmc that might (hopefully fix my other problems). there's no move to phone memory in the options menu.
anyone?
3. i have the virtualpc but its very slow. do you have the cracked version of the editor?4. >:P i aint dumb dude! what i meant was i have messages in my folder (w/c uses the mmc memory) that i want to move to my phone memory. what you're saying is choosing the memory that the phone's gonna use on coming messages before you set it to desired destination. i have the messages already and just want to move them to the phone memory so taht i could format my mmc that might (hopefully fix my other problems). there's no move to phone memory in the options menu.
anyone?
3. Why? For one, the Nokia Series 60 Theme Studio is free. Secondly, asking for and posting illegal copies or software or keys for them is unacceptable practice on this site. Anyone doing that will be banned from these forums.
4. When you change the "memory in use" setting (from phone memory to memory card/MMC, or vice versa), it will move the existing messages, too, from one to the other. It is an either or situation; the phone will not use both locations at the same time.
there's only one thing left to do...FORMAT YOUR PHONE.
2 ways to do this...and theyre posted on a sticky.
Originally posted by N/A
3. Why? For one, the Nokia Series 60 Theme Studio is free. Secondly, asking for and posting illegal copies or software or keys for them is unacceptable practice on this site. Anyone doing that will be banned from these forums.4. When you change the "memory in use" setting (from phone memory to memory card/MMC, or vice versa), it will move the existing messages, too, from one to the other. It is an either or situation; the phone will not use both locations at the same time.
3.the editor i have is too complicated (you have to get 2 versions and open the demo and replace it with the other one, but i couldnt get it to work). i know its free (therefore, im not asking for illegal copies. "crack" could mean so many things, so if anyone have legal copies of the app, it'll be highly appreciated if you would spare me a copy. after all, that's what's this site's all about, (legal) sharing and helping?
4. i tried doing that since before but it would never do what you said.
one thing i noticed about (#1) it works fine if i remove the mmc and open my phone without it then shut it down and put on the mmc. then it works then like after a day, the problem re occurs. and now the unerasable messages from the sent and draft folders 11messages.
i think its the mmc. i think i have to reformat it, but i have to figure out how to save my sms to phone memory first. i dont want to bring it to any tech yet coz they might reformat the whole device and my messages might be all gone (just what happened before!) my sms are very important. yes... i am very sentimental!
:P
anyone?
get a pen and some paper, write down all your sms on that. 😊
mondo wrote:can someone please help me on the ff:
I was trying to Sync my phone using PC Suite v1.1.0 on XP and kept receiving thr same message.
I kept flashin up on the PC with the same appointment at the time it crashed.
I deleted that appointment and it worked 😊
Remembered that is one that was bluetoothed to me from a Samsung phone - so it must have comtained something the phone did not like when trying to sync
Hope this helps 😊
I sorted out the no ringtone and notification off message thing on my 6600 by formatting my memory card this also took care of a couple of messages in the inbox and drafts that would not delete....
Hi
what can i do if i try to access to my MMC in 6600, it says Phonecard corrupted.. is there any way to retrieve the data?
Thanx in advance
Abinanthan b
