Download hier: www.chaellers.ch
Hello there.
I'm so curious about your Patch - but I'd first like to know a bit more, before i install it:
1) Does it run on OSX 10.2.8 - or do I need OSX 10.3...?
2) Does your Patch allow isync to sync ical and addresses?
if so, I would be so relieved!!
Greetings from Berlin, Till.
Hi Bill - it allows sync with ical and adress. I use 10.3.2 - but it will work with 10.8 also.
ok - I tried.
First it seemed ok:: I succeeded adding the 6600 to isync, the phone was then asked for a connection, I clicked OK, then I tried to sync - but no reaction. Only this rather short error message::
Synchronization failed!
Friday, January 09, 2004 22:03
I'm on 10.2.8 with bluetooth 1.3.3
best regards, Till.
the other thing that happened was that after pressing -sync- the phone was asked to accept a connection (wow!), i clicked OK, but then this rather well known error message::
Friday, January 09, 2004 22:11
|NU.tille| Could not connect to NU.tille. SymbianConduit may not be correctly installed.
Can't synchronize contacts to NU.tille: device is not available
Can't synchronize calendars and To Do items to NU.tille: device is not available
...any suggestions...?
thanx! greetings! till.
hi
i used the patch, i changed the symbian conduit bundle and i still can't sync my address book or ical to my 6600😞 i get the so-famous error message: the symbian conduit may not be correctly installed. however i can send vcards(one by one) but i would really prefer to use isync if it were possible. using a DP G4 running 10.2.8...help please!!thanks
Hi Till and Wadat,
I noticed that you both might have the same problem as I had before. Please refer to this thread, it might help you solve your problem:
All About Symbian Forums > Symbian Based Devices > Series 60 > Nokia 6600 > Problem Apple iSync with 6600 solved
Check out page 2. I got mine fixed from Husby's suggestion.
Good Luck.
hey thanks for your reply
i did the repair and i'm sure it helped somethings but not isync to nokia: same old message-rf symbian conduit...
any other idea?
also when you send vcards is there a way to send more than one at a time?
thanks again
Did you try the suggestion given on the other post? I think it's your conduit set up that's not properly configured. Just go to: System/Library/SyncServices/SymbianConduit.bundle/Contents/Resources/
then manually replace the conduit setting. You'll find the steps on page one of the previous post (All About Symbian Forums > Symbian Based Devices > Series 60 > Nokia 6600 > Problem Apple iSync with 6600 solved).
Hope this helps. Good Luck.
really thanx for your help but my problem remains...i wonder if dont need a new clean SymbianConduit.bundle any idea where?
also when one repairs permissons with disk utility does one need to do it from the osX install cd? that's how i did it but it actually didn't do much: the permissions i changed remain...???
thank you for helping
That's the culprit. You have to do it straight from your running system. Just go to your Application/Utilities/Disk Utility and do it from there.
well, i just did that and it doesn't find any permission problems...which i don't believe is true😉
anyway i tried to sync after that and still nothing but this message about symbian conduits not being installed properly...
don't know what to do anymore.
