Hello
My Pics or Videos are always stored onto the internal memory. How can I change the default place to have them stored? I remember having to format my p800 once because the internal memory was full. I would like to avoid that on my p900. And anyways I would like to have my pics on a removable memory.
How are you transferring the pics/vids? If you use PC-Suite (the PC sync software that came on the CD with your P900) you can just "drag and drop" the files straight to the memory stick.
I think he means when he uses the P900 to take a video\picture how can he change the default file location (is that right hardegger?).
If that is what you meant, then when you open up the communicorder, simply change the folder in the top-right corner to one on the Memory Stick. You should only need to change this the once and it will remember and use that folder as the default from then on. I have created a folder called "General" under the media folder on my MSDuo and this is set as the default.
That's It, thanks for your help Guys! Judy
