How can I get menu bar on Programing tool in Nokia 9210?
1 replies · 2,364 views · Started 02 September 2002
Hello,
I'm just to start to program OPL in Emulator Nokia 9210. After installing that software, I could not found a menu bar on the editor program. Do I need to install more librery?. If I do were can I get it ?.
Thank in advance,
Veasna
If by "Menu Bar" you mean the commands on the 4 buttons at the side, then switch away from Full Screen on Ctrl-T.
If you mean the File Edit etc... in the editor itself, then you just hit "Menu" to the right of the space bar.
If you mean how to get a Menu showing in your OPL apps, then let's shuift the discussion into the Developers forum and take it from tere.
