Hi, i lost... I put a bounch of .sis file on my memlory card (via my pc card reader) and i can t find them in my phone. I don t have a cable or IR or Bluetooth. So using the mmc reader is my only hope 😉
Is it normal that my phone doesn t show me the .sis files? How can i get it to work?
thanks a lot
Where are my files???
If you put the .sis files in the top/root directory/folder on the MMC then on the phone open "Manager" (also known as "App. Manager" or "Application Manager"😉, scroll down until you see your installable programs & install them (Options -> Install, for example).
Well, I ve just done it. I put the .sis files on the root foder of the mmc ( an pretty much in every single folder of the card just to be sure 😉 ) and i still can find them in app. manager or apps. Manager tells me "no data" and Apps tells me "no installed applications" both in the downloaded and application section. What can I do?
once again... where are my files 😃
