Auto-Start/Lunching "Messages"
1 replies · 1,466 views · Started 09 January 2004
Hello,
Every time, right after I reboot my P900, I see in my Task Manager (Sman, for example) that the "Messages" application is working, without activating it before.
well... I'm not using Tracker or anything like that, so why it activate itself all the time???
If you don't know, can you please check this for me and reboot your phone and tell me which applications are running there (Of cours, not including the users of apps. like "Autostart" and "Tracker".
I want to know if this thing is normal (Auto-lunching "Messages"😉.
Thanx a lot!
Ido.
messages loads on startup automatically i think, well, that's what i've found to be the case anyway, i've set sman to load contacts, control panel, unreal player on start up but not messages as it loads itself up
