Hi ppl
Ok so i just downloaded ultra mp3,now how do i get it onto my phone from my desktop?
Tried dragging it into the mmc but nothing and fexplorer couldn't find it either?
Cheers
Hi ppl
Cheers
Can you not just double click it and it will install onto the phone?
Thats how the 7650/3650/6000 works...
Else send it to your inbox and open it from there, and it will install.
Will
Nothing happens when i double click and i don't have an inbox on my mmc?
ideas?
Ok i managed to send it via bluetooth and fexplorer sees it in my inbox..........what next to get it going?
Inbox says'unable to install'when opening it
Thats wierd - do you still have the box your phone came in??
out of the subject u have an n-gage with an mp3 already y u need??
Just wanna be able to customise it and have more controls than just pause and stop.
yeah i still have the box
T.
I've tried it on my N-Gage and I have to say that it sounds awfull compared with the build in one.
It looks good but since it's about the music I wouldn't recommend it.
Installing with double click will only work if you have pc suite installed and a active bluetooth connection with your phone.
You can use the usb cable to move the sis file to your mmc and use FExplorer to install the file (just open the sis file from mmc).
I myself use a card reader ...
