?? How to use an mp3 as ringtone ???
3 replies · 9,920 views · Started 10 January 2004
Hi, i'd like to know if there is anyway i can use an mp3 as a ringtone. I just got mp3player and i works great. So now, that i can listen to mp3 can i set them as ringtone?
Thanks to tell me how.
appreciate it
Well, once again i figured it out by myself 😃
just looking around and it worked. So now, there is the how to do :
1) pick your favorite song .mp3
2) cut it to get the best part of it ( you won t need the full song anyway so 30sec should be enoug). More over it s a lose of space on the mmc.
3) then convert it to .wav
4) put in the the sound/digital folder of the mmc.
5) now you should be able to find the .wav song in the profiles
have fun 😃
dear bro
any body have the software which set mp3 as a ringtone in nokia 6600 if have then plz send me thanx
Well as far as i remember (coze my 3650 died)
You can not directly use an mp3 but first have to convert it to a wav.
For a mp3 --> Wav converter browse google.
See my explanation here above i thought it was pretty clear.
Hope it helps
Thom
