internet help
6 replies · 1,342 views · Started 10 January 2004
i wonder if anyone can help me , i recently bought a second hand laptop (toshiba tecra 8000 ) i loaded in my tesco disc and added my details and everything works ok but when i click on a link in a web page that opens up a new window the new window is blank (it has all the normal tools like search favorites etc . )just white with no address in the address bar .if i copy shortcut from the original link and paste it in the new blank window everything works fine .also i cant click on a link in outlook express , my cursor changes when i move over it but clicking on it makes no difference all i can do is copy shortcut and paste in new winndow.Hope someone can help me , ive put my laptop next to my pc an went through all the internet settings and they are the same so am i missing something or does the prob exsist somewhere else .
thanks
gadget
it is just what happened to me once. but the bad thing is i still don't know why it was happened, but when i installed a newer version of IE the problem was gone. i think that this problem is not about the settings, it is a fault of IE. but if it is not i really don't know how it is solved by changing settings. or it can be a third party app. did you installed any other application from internet after re-installation of the OS? because some applications contain some other harmful applications, and these can do that too.
i suggest you to try other browsers instead of IE... and i strongly suggest you to try Opera. It has lots of very useful and very handy features and very much better than IE.
