if i buy a blue tooth ear piece can i still listen to the radio. i no that the wire acts as a arieal but can i do something to it and still use the hand free adapter. thanks gareth
bluetooth ear piece
No can do. You can't connect a Bluetooth headset with the wired headset at the same time 6 the FM radio needs the wires as you pointed out.
You can attache the earphone adaptor (the one provided so you can use your own headphones) to the N-Gage and use the Bluetooth headset.
