Upgrade RealOne Player
6 replies · 3,438 views · Started 11 January 2004
Dear all,
Does the realone player in 6600 can possible be upgraded like on PC.
Because some files can play on PC cannot play on mobile possibly missed some plug-in (like Real2.0).
Does anyone know how to install/upgrade them.
Thanks.
Go to mobile.real.com
The new version available in the developers section plays mp3's and streaming on UK networks now works.
Will
Can u please post the EXACT download link for 6600 causer i can't find it.It's only for 7650 and 3650.
I had the same thing and ended up at the download page for the 9210 even though I selected the 7650. All I did was look at the address bar at the top of the screen and change the numbers 9210 to 7650 and then hit return. The new page for the 7650 then shows up.
I got lost looking for it as well. Where exactly is the developers section?
Saf
Thanks Will, still bit confusing, used advanced sis 1mb file, it loads ok but still in 'beta, very buggy
WARNING AS USUAL IT DOESNT APPEAR IN MANANGER FOR REMOVAL, SO LOAD ONTO CARD!!!!!!!!!!!!
Still doesn't find Mp3's ?
