email settings
3 replies · 2,851 views · Started 11 January 2004
hi i have my 3650 mailbox configured for my btinternet email and this works fine but its connecting useing a dial up rather then gprs .i have gprs activated on my tmobile account but what is the best way to change over on my phone. do i go to tools - settings - connection - access points - select btinternet then scroll down to data bearer and change to gprs . is it as simple as that .
thanks
gadget
Goto
messaging/options/settings/email/mailboxes
and select you current mailbox
Goto 'access point to use' and select your T-Mobile GPRS acess point (I simply use my 'picture messaging' one)
You will also need to change your outgoing mail server to
209.228.37.13 which is the t-mobile smtp gateway - all the other settings can stay the same if you with to continue collecting your BT mail.
People wont see that you've changed your outgoing server as your reply address will still be your BT one.
Best
Will
thanks Will works a treat , tested it out with sending and receiving .its alot faster aswell
gadget
Hi there, I am new to the forum so I hope u dont mind me busting into the conversation like this.
How do you set up the email for BT Internet on a siemens sx1 on the O2 network. I have tried and it just times out on me. This is not using wap dialup but using the O2 WAP GPRS thing. I am new to this stuff- help me!!
Chris
