6600 Bluetooth Dongles
4 replies · 2,611 views · Started 11 January 2004
I brought my Nokia 6600 on friday and I am looking to buy a bluetooth dongle.
The one I am looking at says it works for n7650 and n3650 and many more so is it likely that this will work with n6600 also?
btw the model is the: W-Linx USB Bluetooth Adapter
Bluetooth dongle should be a bluetooth dongle, the fact that they say its compatible with those phones means it will be compatible with your one, but that without taking into effect that the dongle may not be very compatible with your computer - your settings - your software. In my experience all bluetooth dongle are usually a pain to setup but my only advice is to play around with all the setting and read these forums eventually you will get it to work and that way it might stay for a long time, until you get a new phone/computer/dongle etc...
I thoroughly recommend the 3Com model. Only because it's what I bought and has given me no trouble whatsoever 😃
3Com
Rob.
All I can say is that I never had any problem what so ever with my Conceptronics CBTU Bluetooth dongle.
It comes with it's own software and there are two versions depending on the range: 10m and 100m.
You'll found more right here
Conceptronics CBTU
Attachments: cbtu.jpg
