does anyone know of any working software that allows you to connect to MSN Messenger on your Nokia 6600....?
many thanks...
many thanks...
Agile Messenger should do the trick!
Agile Messenger not working on all places...
here i can't connect .. stay on "Connecting to the Master Server..." forever 😞
cya!
I gotta say it worked just fine for me bothwith ICQ and MSN networks.
Yup no problems here maybe its your networks GPRS system.
will it connect through wap ?
Nope... You have to make an GPRS internet access point...
Make new access point:
(I wil make a list below with things that should be in the fields,just follow it down...)
-(optional name)
-GPRS
-Internet
-none
-no
-****(leave the stars as they are on default)
-secure
-none
Hope this helps...
Cheers
RayGun
Originally posted by RayGun
Nope... You have to make an GPRS internet access point...Make new access point:
(I wil make a list below with things that should be in the fields,just follow it down...)-(optional name)
-GPRS
-Internet
-none
-no
-secure
-noneHope this helps...
Cheers
RayGun
The settings depend on the network. 😊 For example, for O2 contract users, it's 'mobile.o2.co.uk' instead of 'Internet'.
That most certainly is correct,j2k.. My appologies.. forgot to mention that this is what works here.. Btw,I have made this list once or twice before and I think I remember some ppl from other parts of the world having it working good for them as well..
so,unless you guys are on O2,try it out... 😊
Cheers
RayGun
HI!...
I remove Agile Messenger because don't connect...
And installed TIPIC ME (Free version from www.tipic.com), you simply create an account there and you will connect from the phone too, and you can install the PC Version to assign the transponder for MSN, yahoo etc...
It's cool!... work fine with all IM services at the same time too (MSN, Yahoo, ICQ, etc)
Many good options...
this is a good alternative if Agile Messenger don't work ...
cya!
