I quite new to the N 6600. i just dl some .sis files for the theme for N 6600. but i duno how to transfer the file to my HP. can someone teach me?
Help on d/l of Themes
The simplest way to transfer any file to your phone is via Bluetooth or Infra Red, Bluetooth being the quickest.
You will need to buy a bluetooth adapter for your PC if you haven't already got one. TDK & 3Com are some popular makes, but there are many others. Search the forum for recommendations.
Once you have installed the Bluetooth unit on your PC, it is a simple case usually of dragging and dropping the files in to your phone, either by using the bluetooth software or PC Suite which was supplied with your phone.
Infra red works in much the same way, except it is slower and requires line of sight between phone and IR adapter on the PC.
Failing this, you can email the .sis files and pick those mails up via your phone with an email account that you have set up.
My personal choice is Bluetooth. It's an invaluable tool that allows you to transfer large amounts of data to your phone at reasonably quick speeds, and that's a good thing with the 6600 and it's memory capabilities.
Cheers,
Rob.
