Operator Logo
9 replies · 2,342 views · Started 11 January 2004
Oh, come on - at least do a search first mate.
This subjuct has been done to death!
You need seleq or simular prog - have a look in the shop.
Will
Bolox, shows how much you know!
There is one file in which you can replace the original op logo with another. I did a shit one and want to revet back to the original and now cnnot find it. All I want to know is where to find it!
Enough with the aggresion... Mate....
Then why did you not ask that question in the first place...
Just delete your shite one and re-boot.
The original one is then normally put back.
And I know quite a lot actually... mate... and was not being aggressive...all this info can be found by searching, chill out.
If your network does not replace it, let me know your network and I can prob send it to you.
Will
The logos are in c:\system\Apps\phone\oplogo
How you add them, modify them, delete them & where they reside are so often asked and answered that it should be very easy to find the existing answers from existing discussions using the search feature of this site.
Originally posted by weebroonieuk
kept your cool there will
Well he started it with his silly question - then swore at me!
I thought this was a discussion forum, not a FAQ for people to lazy to hit the search button 😉
Best
Will
Will
Perfectly legitimate response from Will.
As he says, this subject's been done to death.
Rob
Rob
I definitely agree on both... your opinion and your signature.. 😊😊
Cheers
Raygun
