Help with bluetooth
2 replies · 1,464 views · Started 12 January 2004
Hi, Im having a problem with my bluetooth usb. When I install it and try connecting it with my nokia 6600 it says that there is an error establishing connection with the phone. But when I search the phone, it finds it. Please help, thank you.
Try enabling BLUETOOTH SERIAL PORT service on any free COM port you've got.Or any other service the 6600 can provide:
Push Object, FTP transfer etc...
I was having difficulty with my Bluetooth connection also. When I wanted to send something from my computer to the 6600 it was just a case of right click "send to - Bluetooth - 6600" but when I wanted to use Nokia PC Suite or just have a serial connection between the two I had nothing but error messages. Eventually by trial and error I found out that my Norton Internet Security was preventing a connection. When I turned off the Firewall I got connected straight away.
Though your Bluetooth devices are compatible there will also be some computer setting which has to be changed. Have you tried tech support for your Bluetooth adaptor?
Saf
