does anybody have the original default theme of the nokai 6600? if i'm not mistaken the picture looks similar to the nokia home page of the 6600. it's a guy right beside car and a lady on the right side. if anybody has it kindly email it to me at [email][email protected][/email]
thanks in advance.
Open the menu, go to themes. Make sure you have selected the phone memory. The default theme is strangely called "Default" 🙄
Select and apply.
If you deleted it, then the only way I know of getting it back is performing a reset/reformat.
Search the forum for the correct procedure.
Rob
I dont think you can delete the default theme.
The 1 U are looking for is EURO Version (Car and the girl at the side). The other default Theme is Colorful Picture (3D Picture).
Aaah, never knew there were different themes for different regions 😊
Either way, if you have deleted the Default theme, and as Elton says, this might not be possible (altho' i'm not brave enough to try !! LOL) then as far as I'm aware, the only way to recover this is to reset/reformat.
If anyone knows of a way of recovering the Default theme, please let us know....maybe we could all swap the regional themes 😃
Rob.
Actually is very easy to get back the original theme from the phone. If U not sure that U deleted or Not.😃 First U install any theme and apply as a theme, then U go to Manager and uninstall the theme that U just applied. After that U turn off and on the phone, it would be the original theme. This is not harmful at all. 😉 😉
Well spotted, thank you 😃
Rob
man i have the phone made by nokia so i really dont have the theme but iwould like to get it if any1 has it please paste the link or dont feel lazy to send it to dis [email][email protected][/email] pls i need it guys
If you are referring to the Default 6600 theme, there is nowhere we know of that you can download it. Follow the instructions in the above posts to recover it on your 6600.
Rob.
