EMame on 6600 - experiences?
9 replies · 3,200 views · Started 12 January 2004
Hello everybody,
I desperately tried to get the emu EMame up and running on my 6600 - but it always crashes before I can do anything about it. Has anybody similar experiences - or even more positive experiences - and maybe even some advise what to do?
So far I've tried the EMame V.95, V94, Micro-EMame, both on thePhone-memory and on the extra-memory...
EMame is always closed right after starting it with the error-msg "Progr.geschl.EMame" which is german and means something like "Application close EMame"...
...help?!�
Thanks, Greetings, till.
Hmmmmm... Interesting one... Both emame 093 and 095 crash on trying to load but 094 seems to pretty much work MOST of teh time (but not all)
Ive got firmware 3.49.1 (Orange UK) and have installed it on the memory card... Ive tried quite a few simple/small ROMS and they all seem to work ok...
Havent managed to find the micro version yet but I'll give it a go soon... Lots of people seem to be reporting problems running emame on 3650s, so it may also be worth a visit to their forums??
now I gave it another try::
firmware 3.42, EMame v.94 installed on the phone's memory, frogger waiting in his EMameRoms-Folder on the Extra-Memory...
Same crash-response, absolutely no chance to choose from any options, only to push the OK on the upcoming error-message 😞
Could it be some other app I insalled earlier? like the c64-emu Frodo, or the NES-emu YewNes I installed and deinstalled a couple of times?
...i dont know...
...shall i just wait for new sw-versions to come?
...or should i meanwhile reboot my phone?
greetz `.� and thanx for your suggestions!! t...
fw 3.48.0
emame 0.95
"app closed !" if sound is active...
i also tried installing frodo previously but i dont think it really matters at all what you had installed already.. neither frodo nor sidplay worked. yewnes has no sound... wildpalm emus (zxboy, goboyplus) suffer same fate (sound == crash) so i think its really firmware fX0rin series60 standards...
isnt there some way to figure out the internal diferences between firmware versions? like some sort of nokia forum or page where they actually explain it to interested devs what they are messing about with inside the damn OS?..
...if sound is active `.� drives me mad:: With Frodo it worked to turn off the sound _before_ it crashes but with EMame i seem to have no chance since it always first crashes.
But instead I found some NOKIA-Dev-Forum::
http://discussion.forum.nokia.com/forum/index.php
...but it won't really help me much, since I'm not really into programming THAT much 😞
*huh*
when you launch emame it'll put you on the game choosing screen usually, but you can just go back (right select button)before getting into the game... and you'll be in the main options menu where you can do options -> settings -> sound off
i havent gotten _anything_ to work on frodo, it crashes on load... i just see white letters on bluescreen saying paused and then app closed... :/ how the hell did you manage to get options for it?
you sure you didnt swap emu names by mistake on your last post? 😊
Press the left menu button as soon as it starts..disable sound.
I have frodo working very well.
Beachead 1 is very cool. Pity I can't get beachhead 2 to work 😞
Also..Dropzone, and galaxians, manic miner, jet set willy, and the best of all............
Leaderboard (way better than all the golf-games other phones have preinstalled)
HTH
@psychicsymphony:: now it's getting interesting... Reading your post I tried to start Frodo - and the same appeared to my phone:: Blue-Screen-Paused-> Crash.
Then I thought it might be because of yesterday when I wanted to show off with Fodo, Phone in silent mode, Frodo did start but didnt load any ROMs properly, instead the poor emu crashed.
So I rebooted the phone - and now Frodo's back but not loading ROMs as far as I understand it.
And again about EMame:: I just don't have any choice to push any Button but the ok-Button once it has crashed - so I also neither can not push the OPTIONS-Button, nor back-Button... EMame crashes before that, no Game-Choosing-Screen, nothing but "Appl.closed:EMame"...
And:: yep X) although it gets a bit confusing I'm still quite sure which Emu does what... or not `.�
yakkob: yay! thx for tip! works! colors suck (where's the purple?) , some fast blits give fucked up results, some demos refuse to load. but atleast its working, it's only 0.5 version so i guess its normal that it's so handycap.. cant wait to check sound working properly on it 😃
till: spooky. tried uninstalling and installing .95 again?
it _should_ give you the donkeykong picture menu on first startup... where you can easily go to option and turn sound off before trying any game..
