where/how to get videos for ngage
2 replies · 1,596 views · Started 12 January 2004
can anyone tell me where i can get them from? also i read a thread about using this program to convert them, but i dont have the program or the movies on my computer...thanks
unfortunately films are copyrighted and so is any other material unless you created yourself or you have been given rights by someone else to use it. I would recommend that you download the software for mobiclip www.mobiclip.com and go to www.dvdrhelp.com and download virtua dub and a few codecs(divx xvid and mpeg2). Then you are set up to convert movies to mobiclip format. If you want some instructions on how to get movies to play fullscreen in mobiclip i can send you a quick tutorial. All the above software is free you just need to find the films and I am sure someone as resourcefull as you will find something. There are other formats such as 3gpp which you can create using nokias multimedia converter which is also free. Good luck
