SmartLauncher Still Rocks! 😃 and now i am using again ...
Because is faster to show and browse the main icons menu than default nokia Icons Menus ...
I like the combination of themes + smartlauncher
all go faster because SmartLauncher CLOSE the normal system menu process...
and you can make folders into folders too, like a PC...
Well.. now i am using both.. and i already make it an SmartLauncher Skin for each one of my themes 😊 ...
So i can assign the main theme and then the SmartLauncher skin that match with it and the icons 😃
This are the screenshots of the SmartLauncher Skins for my themes :
aefox,
i saw ur skin on the net for 7650, but i couldn't find any of your newly posted 6600. if u are willing to share your skin, can u let me know where can i download the latest 6600 kins u created for aefox? i am using your theme aefox blue now.
thanks
hi!...
ok here is the link...
AEFox SM Skins
Remember to use SkinEditor (freeware) to assign some icons apps. If you see some icon with no app assigned it's because you don't have installed some app.
cya!
hmm the icons seem to have few colors..look like 4096, did u use them from old themes?
Aefox....
Did you have to pay for sLauncher again ?
The reason I ask is that the registration code you get when you purchase it is linked to your IMEI number, therefore, mine is linked to my 7650.
I resent having to pay all over again.
Rob.
HI!..
i sent an email to symbianware talking about my upgrade to 6600 and my new IMEI, and they reply me another code ...
About the colors of the icons... i used the original 24 bits icons to put on the smartlauncher, but i think that SmartLauncher use 4096 colors for all the skin... that's why it's faster than normal nokia themed system, it's like the default theme of nokia that work faster because the default theme use less colors for the icons and no background...
I think that is not a big deal, it's faster and look good enought too...
cya!
Originally posted by AEFOX
hi!...ok here is the link...
AEFox SM Skins
cya!
yo!
thanks a million!
it's so nice!!!
aefox,
i realised that i do not have the themes: pro and fusion...
anywhere can i find them?
thanks again...
HI!..
Go to www.Zedge.no
on 6600 themes.. there you will find them..
cya!
AEFOX!!! you rock!!!
BTW, where do i save the skins once i upload them to my phone? thanks!
hi!..
When you click over an .skn file, smartlauncher recongnize that and save the skin on the list...
anyway all the skins are saved on:
C:\system\data\LNSkins ...
or E drive same directory if you installed
SmartLauncher on your Mickey Mouse Club Card 😃 ...
cya!
