Hello,
I have a problem with my 3650 and I'd like to re-initianize it in using a code like *#XXXX#
I have ever seen it but I don't remerber where...
Thx for your reply..
NB : I can't do that by the menu because It makes an error...
Hello,
YES ! !!!
Thx to you GhostDog !!
I have read an other post (VIRUS) and I saw one of your reply !
I installed Wildskinz and I forgot to disable it....
Thx a lot 😊
No problem 😃
Originally posted by dionaea
Hello,I have a problem with my 3650 and I'd like to re-initianize it in using a code like *#XXXX#
That might be *#7371#.
The code is *#7370# but his problem is already solved,so no need for the code.
