I have a weird problem with the 9210. The clock on the cover is 2 hours ahead of the clock that is located on the color screen. I did some adjustments with the daylight saving time. First the time difference was one hour and now it is two hours... I could keep on doing these adjustments until these clocks show the same time, but it is no longer working like that. Sometimes when I remove the battery, I have to adjust the date as well - it often thinks it is November last year. What to do, i.e. what files to update or time to change the whole OS? The version is 4.13.
I've got also another problem with the same phone. When trying to login to my ISP, the username gets some extra characters while login process and I can't login. e.g. My connection is called "work" and my username "anttih". Then the username is "work/anttih" and not only "anttih", like it should be - says my ISP. Again, which file to alter or replace to avoid the problem? I have tried to use the backup files and make new connections, no effect. And no, rebooting is not working...
-Antti
