problems with Active Today from Cibenix
1 replies · 2,442 views · Started 15 January 2004
for some time I used Active Today from Cibenix, now I had to reformat my phone.
After the new installation of my programs Active Today don't want to start. I always get the message "Progr. geschl. ATS60".
I can remember I had this problem some weeks ago when I installed Active Today for the first time. I don't know how I solved it that time but I get it working.
What I would like to know is, if someone has the same problem and knows how he has solved the problem.
thanks
Dear friend,
I've got the same problem as yours!
I worked by myself trying to understand the reported problem you described to us some days ago.
I noticed that:
if I RENAME the folder SYSTEM on my MMC or I install AT in Phone Memory and I remove MMC, Active Today works but if I create another folder (even empty) named SYSTEM or I insert MMC,
apps gives out the mentioned error message: APP. CLOSED ATS60 or yours in your german version !!!
It seems AT doesn't like a folder called SYSTEM in my MMC..even an empty folder !!!
Is there any INI or DLL files corrupted to delete or something like that?
I really don't know but I am working on it finding a solution but it seems to be a really hard work!
Any help will be really appreciated ! 😊
Please help us finding a solution.
Thank you all very much in advance.
Kind Regards,
SP
thedoe!! wrote:Hi,
thanks
