Auto KEYPAD LOCK ..any??
6 replies · 10,515 views · Started 15 January 2004
Hey guys,
Dunno if somebody askd this question already but i wanna know if theres an app for N6600 that locks the keypad (NOT LOCK CODE) after a set time... before the 7650 has its keypad lock.. it locks automatically when u close the grip... i dont think it applies to the 6600... please mail me or help me out! thanks!
[email][email protected][/email]
left nav key followed by the * key will do it.
If you want it automated you can download jjlkeylock from handango (it's free)
http://www.handango.com/PlatformProductDetail.jsp?productType=2&optionId=1_4_2&jid=FDD85A1B8EEFF7E9E58X81F4BAX239E9&platformId=4&siteId=1&productId=90076&sectionId=0&catalog=20&txtSearch=jjlkeylock
Then you can also make it autorun on bootup by using autoexec.
http://www.handango.com/PlatformProductDetail.jsp?productType=2&optionId=1_4_2&jid=FDD85A1B8EEFF7E9E58X81F4BAX239E9&platformId=4&siteId=1&productId=55609&sectionId=0&catalog=20&txtSearch=autoexec
Best
Will
The Extended Profiles program allows you to schedule the keypad lock automatically after a minimum of 30 seconds of idle time (it can also be set to 1,2 5 or 10mins). And it has other fancy features 😊
Hi, first post 😊
I know this is the wrong Forum section for this, but as you're on the subject....
Is the JJJKeylock avaliable for the Nokia N70?
Feel free to not answer, and make me post the the N70 forum section.
