Is it posible to make new folders and make them hidden, just like in windows?
Can't find it!
Ren�
Can't find it!
Ren�
I don't remember seeing it anywhere. Another feature that is missing from the file manager.
It is possible to change the attributes of a file or folder using the RFs class in C++.
[quote="cmatthee"]
It is possible to change the attributes of a file or folder using the RFs class in C++.[/quote]
I'm afraid i don't know what this means....
Ren�
You cannot change the attribute of folders to hidden, only to read-only. Check properties (ctrl+p) in the File Manager.
Regards,
Tilman
Ok... Thanks
Maybe someday someone write's an application for this purpose. (or as part of an application)
I would be intersted.
Ren�
