Am desperately trying to upload some Ogg files onto my P800 but I keep getting an error message ! It works fine with other file formats, what am I doing wrong ?
you need to use something other than your pc suite, unless you install the latest one, which then allows you to transfer ogg files to the audio folder, you can either transfer the file via infrared or bluetooth and then move it to the required folder, or use epocwares file manager
