i couldn't play musics in music player
it say "Music player: System error!".
but sometimes i could.
Any solution please.
Make sure you have a properly formatted MMC card in the phone (with MP3 or AAC format music files).
If it doesn't help, you could try reformatting the phone (make a backup first as all contacts, messages, settings, installed programs, etc., will be gone). Reformat with #*7370# (keep the charger connected or make sure you have a full battery; you will be asked for the phone's lock code which by default is 12345).
If reformatting doesn't help, take it to a Nokia authorized service center for reflashing.
I try it but nothing happen.
anyway, thanks
how big is your MMC? i have a 256mb and when i got it all i had was mp3s and .aac and everynow and then it wouldnt let me get into the nokia music player but now that i have other apps and games it seems to work perfectly..
but i would also reccomend buying or downloading a mp3 program like ultramp3 or something because they will support any mmc basically..
hope this makes sense
Originally posted by NitroGate
I try it but nothing happen.anyway, thanks
N/A has mistyped the code. That should be *#7370#. Try it again.
Well, the playback quality on 3rd party players just suck. Nokia's own music player playback quality is way better than any other software's...
I entered the code *#7370#
it just do the factory reset. and every thing still the same.
