install default applications
3 replies · 3,725 views · Started 12 November 2001
hello. i just got hold of a bigger mmc and just formatted it. i want to install the default applications in it. what sis file do i need? where can i get it? thanks.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2001-11-12 1421, N9210 wrote
All_Memory_Card_Data.SIS
Available from Forum Nokia here;
http//forum.nokia.com/main/1,6668,5_2_4_1,00.html
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
thanks. im downloading it right now. how about the file All_Nokia_9210_data.SIS? whats the difference with the one you mentioned?
All_Nokia_9210_Data.SIS is the default apps that must be installed on the 9210, the other file installs apps on the MMC, if you are doing a fresh re-install of everything you need both files. If you are only re-installing your MMC then you only need the first file I mentioned.
HTH
