plz help me with this. made this theme but it doesnt look gud enuf with stock icons . need to also know how to chg text color on menu. its always black :S
plz give da links for icons
where do i get icons for da N6600 themes
I do graphics,..also drawings etc on pc,..and also do icons, both completely built-up (like 3d folders etc), but also from real photos.
If you use Win Xp,..and also use e.g. customized icons, the you can download iconpakages from e.g. www.wincustomize.com
(see the left bar - click icon packager)
Icon packages is sort of zipped programs containing all icons, and the program Icon Packager can install/replace all the default icons on your computer in one step.
These icons are of course for windows,so you will have to redo them in size etc in for example photoshop.
A program like IRFANVIEW can show ICO (icon-files)...use this to show and save the icons as e.g. jpg,..so you can work with them in photoshop.
Or you can make icons yourself,..I do that too,..can use real pictures, Photoshop and e.g. Iconxp program.
Or create icons in Coreldraw/Illustrator,..any vectorbased program.
Another way to do it, is to load another theme into the phone, and then use the icons from that theme.
Go to the theme, and "edit",..here you get to change the icons on the 6600,..to use another package from another theme.
BR
Jan
Can you make for you and me a new theme with the icon, wallpaper etc that i give you? you can also personalize it to make it better....download this folder from this site:
http://xoomer.virgilio.it/luca_piazzola/Mio%20sito/Icone%20nokia%206600/
here you can find all. make it than contact me because i wan't download your new theme.
P.S. sorry for my english but i'm italian!!! after you make this theme you can send it to this my address: [email][email protected][/email]
Bye.
