How can I reinstall the system like companies do?
And which tools I need?
Reinstall the system
Some very expensive equipment,like a DCT4 flasher box,and the firmware itself which is not public.
A system would only need reinstalling if you want a firmware upgrade - which is of course being taken care of by Nokia Service Centers. No need to buy those expensive tools as they might not even support the ngage or even be available commercially. Try the hard reset *#7370# and see if it fixes your problem.
