My Nokia Suite, seems to only want to connect through Com port 8. When I try to selct this port in the BT config Panel (and when I create a new serial connection) it only gives me 6, 7, 10, 11, 12, 13, 14, 15, 16.....
When I look in device manager it shows that there are 8 and 9, so why can I not select them in the config panel???
Vey confused and frustrated!
I'm having the same problem. I'm told to connect to COM port 0, but I can't select this in the Nokia connection properties as it is not available.
I have the same problem. Keep checking and unchecking all the available ports and eventually (after 2 or 3 minutes) one of them will connect - just keep trying!!! Seems to work better if I search and find my device in My Bluetooth Places first though.
I don't use pc suite, i could never get it to work so i just right click and select 'send to bluetooth'
