guys, how do you apply themes with a file extension of .utz and .ztr on a p900 and p800? I really need help on this. Thanks
[Edited by Raven]
[Edited by Raven]
Do NOT ask for warez here. Consider this as a warning, next time you will be banned.
Sorry Raven. This is my first time posting here. Not familiar that .utz or .ztr are associated with Warez. Thanks for the warning. 😕
Theme files are of course not associated with warez (unless they have been commercially released). But in the second part of your post, the part I edited, you asked specifically for cracks/key-gens etc., which IS indeed considered warez.
To answer your original question, there are several ways of transferring theme files to the phone. What I do, is use the PC File Manager from EPOCWARE and simply "drag & drop" the files to this directory; C:\system\data\themes\installed.
You can also just beam the files through IR/BT, and the P900 should locate the files by itself.
Btw, welcome to the forum, and please respect the forum rules.
Thanks Raven..😊
Again, I apologize for the warez thing.
Thanks for the invite.
