scratched screen
4 replies · 2,482 views · Started 19 January 2004
How bad is it scratched?
Duraglit (silver polish pads) will clean up light scratches, use carefully though, don't let the fluid seep into the edges of the screen it can be a bugger to remove.
Its got minor scratches but they catch the light and make the picture on the screen look a bit distorted. Anyway I got some of this screen polish stuff.....I bought it ages ago from carphone warehouse and used it. I think that it made it worse!! 😞
Now althought that scratches arent so prominant, the surface isnt flat anymore but I can see areas where the screen polish has "eaten" into the plastic screen. I rubbed quite hard when applying.
Bloody typical!
