Palm TT3 & Nokia 6600
1 replies · 1,644 views · Started 19 January 2004
Hi all!
I just bought a T3 to replace a iPAQ 2215, so far so good 😊
I'm having only one BIG problem, no matter what I try I can't use my nokia 6600 to connect to www, can anyone help? I tried download and installed connection mannager but without success... I was able to get it to work in the iPAQ, but the Palm is *REALLY* different, for example where to put the init string?????
thanks in advance,
mari0
On Palm there are two settings for your network connection. Both are in prefs
- 1st: the modem settings are under "connection" so you might want to do these steps:
* prefs
* connection (upper right selector)
* new
* under details you find the init string
2nd the network is under network and for connection you!ve got to select the one you just created.
also: it should be: "Purple Software SUCKED" cause it ceased to exist and Mr. John Holloway is now running a new company.
