Help Help!!!!!!!!!!
1 replies · 1,200 views · Started 19 January 2004
How to add in mp3 files and load movie into the phone?
I tried copy and paste the movie straight to the p900 directory but cant.
someone pls help, thanks.
and wat the picture size that suit perfect as a back ground of p900?
600 x 800?
help pls
Yeap,
You seriously need to search the forum a bit before starting new topics, not just this forum, but especially the P800 part (since they are basically the same), and believe me, it contains LOADS of information. Any possible problem or inquiry you might have, have most likely been brought up many times before. And you would get the information you want so much quicker than starting a new topic and waiting for someone to actually take the time and bother to reply to questions asked a million times before. Also, please use a topic title that is more describing to your problem.
If you're trying to transfer audio and video files to your P900, make sure you have PC-Suite properly installed (check the SE site to make sure you have the latest version), and that the file types are supported by the P900 (.mp3/.mp4/.3gpp etc.). Then make sure that you have a working connection, and simply "drag & drop/copy-paste" the files straight to either the internal or external memory. That's all the help I can give you right now, because you have given me very little information about your problem to work with.
The P900 supports background pictures in the resolution of 208x256 in FO mode, 208x190 in FC mode and 208x320 for screensavers. But it doesn't really matter what size the pictures are in because you can just adjust them before applying anyway (Control panel - Display).
