quickword for S60
2 replies · 1,540 views · Started 20 January 2004
When I bought Quickword thru Handango I filled registration form according to instructions and received registration key. The reg. key does not work with my 6600. Also there is no replay to my mails to iGO.
Does anybody really use registered version of Quickword?
Regards!
Send me a mail...e-mail removed.
I might help you...
-GhostDog edit-
Unless you are a employee of the company who developed QuickWord or Handango(very unlikely) i doubt you can help him.If you can,there is no problem if you post your "help" in the forum so everyone can learn and be helped.dg100 has payed for the software and he doesn't need to use some modified/cracked application that could possibly damage his device.We don't like warez here.
dg100,why don't you contact handango,ask for a refund,that will probably generate the right code 😉
