does anyone know what application i should get if i wanna view chinese on my P900?
the only language on my phone right now is "UK English" ... does anyone know if there are any language packs that I can download to change that?
thanks!!!
thanks!!!
I believe SE produced a new phone for the chinese support, think it's called P908 or something..😮
i believe the P908 is the China version (w/ Simplified Chinese only)...
i'm wondering if there's any external apps. that I can install which will allow me to view Chinese on my English P900...
thanks guys... 😃
U can install the Chinese package for P800 ..... it can work in P900 as well ...... which I am using right now. But becareful ..... someone on other forum said ... its will have problem ..... somehow .....
But in fact .... I didn't face any problem at all ... since more than a month ..... since I bought this phone ... so check it out ....
or I can send u ..... if I can find it some where in my laptop .... 😞
Dear Phillip,
l
phillipe wrote:U can install the Chinese package for P800 ..... it can work in P900 as well ...... which I am using right now. But becareful ..... someone on other forum said ... its will have problem ..... somehow .....But in fact .... I didn't face any problem at all ... since more than a month ..... since I bought this phone ... so check it out ....
Dear Phillip,
Can You also help me to fix the same problem! Thank you very much.
Bless,
Walter
I have same problem here. I have software inside my P900 which can write message in chinese and cannot view chinese ebook. Any software can view chinese word. :?
Hi, can u send me the program for reading chinese in P800.
Thanks alot......
u can email me the detail to [email][email protected][/email]
Thanks again
Walter wrote:Dear Phillip,Can You also help me to fix the same problem! Thank you very much.
Bless,
Walter
I Have A Problem With My Touchscreen It Doesnt Respnd Help Me
