sx1 camera problem
2 replies · 2,186 views · Started 21 January 2004
i deleted the camera .ini file by mistake,what can i do? can i send via bt from my 6600 f explorer? can i format the sx1 please help me
You could use fexplorer and search for the file you deleted - it's sure to be kept on the rom drive somewhere - copy and paste back to where it should be.
Failing that,
*#7370#
That should format the phone. Beware you will lose all you data/contacts etc that are not backed up.
